What establishes a MoBo's value???
brasscorpion
Hi everyone
I am putting together a new PC from scratch...I am going to purchase 95% of my equipment using the internet.
I have a question about motherboard cost.
For example, what makes the Asus Crosshair 259.00 and the ECS KN3 SLI2 137.00???
I understand issues pertaining to quality, craftsmanship, branding and what not...but mechanically and functionality where does the additional $100.00 cost come in if I purchase the Crosshair???
Both use Nvidia 590, both have dual Lan, firewire, built in sound, 16 X 16 SLI support, AM2 socket support and so on.
If I don't plan to overclock and don't plan to mess around with the bios...is the Asus Crosshair too much of a rig for me??? If so, what Motherboard should I be looking at for a fast rig if I run it standard out of the box? I do plan on buying a XFX 7900 GS factory overclocked GPU, new DDR2 memory, a couple of new SATA drives and so on...SO I DO want a fast gaming rig. I want to play games like Crysis, Halo 3 (when it comes out for pc) and I am really looking forward to Hellgate London. I also play games from the Warhammer and Warhammer 40K series...oh yeah and my next purchase is F.E.A.R.
Your input would be greatly appreciated.
Marketing and supply/demand set prices.
I think some of the more expensive boards are artificially priced high to make them more "upscale". Sometimes products sell better when the price is set higher. It's the consumer perception that lower price means lower quality (generally true).
In all truth, I'm amazed mobos are so cheap for the amount of technology that goes into them.
Then again I paid $1800 for a 386 motherboard with 4MB of RAM at one time. Well it did come with the new smoking hot 33Mhz 386 chip at the time too. :D
Sir,
If your not going to be o/clocking and are running everything at stock speeds and voltages the boards with the same hardware should perform equally fast. The asus may use higher quality caps but with all the noise a few years ago with bad caps all mobo manufactures are using better caps now. I would not hesitate using the ecs board in your case.
The asus board has alot of extra features like the lcd display on back and the led's that light up with the flip of a switch. Asus has been known for building high quality and very stable boards for years but ecs builds good boards also. Not all their boards were winners but the last 2 years or so they have put out some decent boards. You would most likely be just fine with the ecs board in this situation. Most enthusiasts these days ,me included, are overclocking and over volting to get more speed for less money. Id bet if you benched both of these boards with the same hardware and software they would bench identical or so close it would'nt make any difference.
The asus has a 3 year warranty and i believe the ecs has a 1 year warranty. Maybe thats part of the cost difference too.
