What else do I need for this WC kit?
DD-D5 Pump
DD-680i Chipset Block
Copper TDX Block for Intel 775 Processors
Black Ice Xtreme II Radiator
Danger Den Round (Cylindrical) Reservoir
Tygon 3603 Tubing 1/2" ID 3/4" OD
Phantom Black FluidXP+ EXT
(4) Scythe USA S-FLEX SFF21F Case Fans
I'm sure there is clamps, but have I got all the basic parts down? Anyone running these parts have some feedback on efficiency and noise?
if you didnt already buy that tygon tubing look on ebay. i found a 50 foot roll of R3600 for $45 plus 6 shipping. which is way cheaper then $4 a foot some sites charge you.
for my watercooling setup im actually using Hydraulic line. Its from goodyear called
Gr14A which is a braided line with a rubber insulate.
