What drivers do u guys use?
Imp
I use catalyst 4.1...not sure if that is good or not...but lots of driver problems...I think I may goto omegas...are they good? anyone use it?
4.1's are working like a charm for me, not a problem since install
if you're having driver issues try getting and using one of the ATI driver removal programs and then install the 3.7's
if those are working for you jump up to the 4.1's and see how those work for you
3.10's since the 4.1's say they have problems with RTCW: enemy territory and im in a clan for it.
I'm gonna use omegas now...I heard they were flawless...I get VGA error when I play Prince of Persia, which is a driver problem
I upgraded from Omega 3.9, which gave me no problems, to the Omega 4.1, which give no problems either
Not impressed with the Omega 4.1's, had some 2D issues w/ my 9700 pro. I am happy with the Catalyst 4.1's, though I received no real gain in performance for either over the 3.10's
3.9's give me best performance and least bugs. I use w1zzards atitool for o/c on my 9800pro
Originally posted by merlin704
CAT 4.1s here. Not a single problem since install.
I was out of the loop for awhile, but you finally got your AIW working, or a new card, or what happened???
I believe you have me confused for someone else.....I get that alot.:(
Don't ask me why, but I got you confused w/ EnderW, sorry:)
LOL I would love to know how you confused my name with his. They dont even look the same. :p:D
