What Driver for X1900XTX
faxel
Just got X1900XTX for a new build.
Asus A8R32
opty 170.. and so on.
I was wondering on a fresh install with no previous drivers should i use the cd driver, cat 6.2 or wait a few days for 6.3 (I doubt i can wait) ?
thanks Slo Gun.
I was going to post one for my X-fi card. What do you recommend?
With xfi just install the components you require off the cd, including the drivers.
Then go onto creative.com and go through the auto update. (Makesure you are using IE for this, it won't work with firefox.)
No probs.
Hope everything works out for you.
My Xfi didn't work properly until i went through the driver update, so makesure you do this.
