Tony Rotten
- Apr 23, 2008
What does "USB 3.0 x 2 (internal)" mean when applied to the "I/O Panel" of a chassis, as in
http://www.coolermaster-usa.com/pro...e=CM 690 II Advanced (nVidia USB 3.0 version)
If the connectors are right on the I/O panel (are they?), how can they be internal?
I know that the MB must have extra header to support these, but so does it need it for USB2 and the USB2 ports do not say "Internal"
What gives? Thanks!
What gives? Thanks!
