What does this Android screen mean?
Modred189
Can't Read the OP
Samsung Galaxy Tab pro 8.4.
Won't boot, and when plugged in the screen shows this
Found this vid Googling it:
Top comment says they fixed it by pressing the power button several times. Sounds odd but worth a shot.
Can't find any definitive answers on it otherwise, but see several other forums and YouTube posts with the same issue on older Samsung phones and tabs. I didn't look at them all though.
It seems to me it would mean that either the battery doesn't have enough charge to boot the device, the battery is now shot/defective, or there is a connection issue between the battery and the device (saw another YouTube comment saying they saw a broken battery terminal and had to re-solder the connection to fix it).
