what does the amp do for you. *is noob*
joethemole
i have a pair of regular headphones, nothing fancy, and wonder why everyone has amps. thx
Well, your headphones need power. So amps take the audio signal sent from the source and amplifies it (adds power to the signal) and then sent to your headphones.
Someone correct me if im wrong.
It's not the regular ones that need amps. Once you spend a bit of money they require amps to sound at their best. There are plenty that are quite hard to drive.
any driver, whether headphone or loudspeaker, has a specific power range they work best with.
This is why DJ speakers often dont work well with one watt, but instead need more like 50-100w just to get going. It's a mechanical thing...the more mass a unit has, the stronger the electromagnetic forces required to get it moving, and since a magnet can only be so powerful and large before it gets to be a design/price problem, your only resort is often to use more power to compensate.
In the case of headphones, weight and space is a premium, plus the magnets are often neodymium (aka rare earth), the most powerfull magnets availible, so there are very few options but mroe power. Fortunately headphone drivers are so small and the magnet is so powerful in relation to the low mass of the headphone driver that very little power is needed.
The problem is many portable utnis (discmen, mp3 players, laptops, etc) have the weakest internal amps you can get, this is for power consumption reasons. So for some phones to sound good, you need a little bit more power....
Now, adding two amps after each other is all fine and dandy for portables, but doing that in a home environment is bad since your stacking distortion from each amp. This is why most home audiophiles run their amp straight from line level.
Stereo recievers and such also tend to have pretty bad headphone amplification as well, so the headphone amp often has lower distortion figures....and if you paid say $500 on a set of Shure E5Cs, would you want to use a reciever jack that might have 10%THD? It doesn't make sense to buy such a high end set of phones to waste their gains on a poor source. This is why even at home amps are used as well.
Well I was close. I got some amps for my Home theater speakers and they output like 200W per channel, and i have 5 channels, plus 1 subwoofer. I guess headphones dont need that much power... duh.
Not the same. A headphone amp is specifically designed for headphones. Many times they are referred to as "dedicated" headphone amps.
yeah feeding a watt into most headphones can kill them.. so feeding them directly off a loudspeaker amp's speaker terminals is basically throwing cash out the window.
Well stepping away from the technical and going back to the heart of the original question. What does for me are primarily two things:
1 - My AKG 501s were not very loud without an amp so it gives me volume
2 - Deeper, richer sound and vastly improved bass. The difference in sound is quite large from unamped.
3 - A thicker wallet and happy neighbors. I have a modest set-up. The headphones listed above and a Go Vibe amp. My wife has the same amp and a pair of SR-125s. In either case we enjoy better sound than a vastly more expensive speakers could provide and apartment neighbors don't have to call the cops late at night.
My friend has a pair of the K1000's, and they really are amazing. I wouldn't use them for "computer" headphones, though :)
I listened to old vinyls through them, and some Diana Krall in SACD. Delicious.
mustang_steve said:
really? man what do they use for drivers on those beasts?
EDITED...I was wrong about the drivers on the K1000, so my post was irrelevent.
