What does PWMIC on smartguardian mean?
Cryptic
I googled it...and nothing came up telling me what it meant. Is that the tempiture of my powersupply? Thanks.
Power Wattage Monitoring In Current.
Sorry, that is just a guess, I don't even know what smartgaurdian is, nor do I care enough to google it.
Sorry. :(
If it's a temperature monitor, it's probably your PWM, or Pulse Width Modulator. The PWM controls the voltage going into the CPU. At high voltages or under full load, the temperature of the PWM can easily exceed that of the processor. Unless it's insanely high and/or setting off monitor alarms, it's generally not something that's a huge concern.
The only reason I ask is because it hits 50c, which is red in color, but as soon as I get out of a game it goes to 49c and drops all the way down to 37-40c which makes the normal green color again...should I be worried? or is 1c over the green anything to worry about? Thanks.
Cellblock already posted it.
Pulse Width Modulator Integrated Circuit
Ok...but I'm asking if its nothing to worry about seeing as how its in red on my Temp monitor...will this harm my motherboard in anyway, or if I can just disregard it...thanks.
Don't worry too much about it, but if your CPU voltage sags or fluctuates, then that might be the culprit.
If thats the case I have a brand new Fortron on the way:) Should be here Wednesday:) Lets hope thats it.
Well.. I guess you didn't waste your money, a good power supply is always useful. But the PWM circuit is on your motherboard.
Yeah, but you said that power sags and what not could cause it, and I dont exactly have a top of the line PSU running right now.
