What do you think?
EQTakeOffense
So, What do you think about the below cooling system?
-- Case --
Lian-Li PC-75 - $260
6 80mm Fans (37 CFM) - $11
-- CPU --
VapoChill LightSpeed - $900
-- GPU Cooling --
226 Watt TEC - $35
Danger Den MAZE 4-1 With TEC Support - $48
2 D-Tek Custom Pro Heatercore - $45 Each
2 120mm Fans (80 CFM) - $15 Each
Dual 3.5" Bay Resevoir - $30
Swiftech S320-12 Auxiliary Power Supply - $160
PolarFLO TT Series Pump - $150
Rough Cost (Including barbs and the like) $2,000 at most.
Because, by the the time I get all the compenets to TEC the CPU, it would cost nearly the same as the VapoChill unit.
The only reason I don't VapoChill the GPU is the fact that there's not GPU support.
