Hi,
I understand, that many of you will say this is stupid and not cost effective but...
I'm going to build a TEC cooled system. It doesnt matter what HW I have @ the moment as I'm building the cooling for whatever I buy after It's ready and tested to be safe for 24/7 (by the way thats only 3,428571 hours a day). Everything in this system is custom designed and made by me except the waterpump and the TECs.
OK, I want to put a 500W TEC on the CPU, liquid cool it with a very short loop without a radiator using a custom made closed waterchiller machined out of a solid block of copper using two 62x62mm 275W (360W) TECs for cooling and they will be cooled in another loop connected to a rather huge radiaror (I'm looking for THE one yet). Both loops will be using a 2000 litre/h aquarium pump as I can get them cheap and they are not loud at all. The actual flow won't be 2000 lph of course as they have a small pressure and the piping and the copper blocks' flow resistance will degrade it.
I personally think that I could have fairly stable temps of around:
50C - coolant on the 550W (720W) hot side
0C - 10C in the chilled loop
~ -40C on the cold plate
=> -25ish core temp (depending on future CPU!)
I definitely have to keep the hottest loop below 50C! The size of the radiator is what will decide whether I will use (a) fan(s) or none at all. Keep in mind I will have to dissipate A LOT of heat!! As the pumps are near silent I could get an almost silent config if I don't use a single fan
Comments?
Suggestions?
Anyone done something like this before?
Coolant for sub ambient loop?
What Radiator? (I was thinking about getting one from a sportscar with a big engine 3-5l, up to the size of a side of a full tower case)
Z
Comments?
Suggestions?
Z
