Looking at this monster- http://www.newegg.com/Product/Product.aspx?Item=N82E16835709001 -for my Asus Rampage Formula 4. Just not sure if it will fit, upwards or sideways on my RF4. Reviews seem pretty good so I'm wondering if anyone is using it & what you're experience is with it? I'm using this ram- http://www.newegg.com/Product/Product.aspx?Item=N82E16820104288 -so it should fit over it, but I'm wondering if it will block my pcie1 slot like my Archon does if I mount it sideways. Archon fits OK mounted upwards. Even an NH-D14 fits upwards but you have to mount the fans to pull not push & D14 fits just barely above pcie1 slot sideways.
