What do you think about this system?
So I just build my first PC, and wanted to know what everyone thought about it.
Specs are as follows:
Cooler Master 690 Case with 550W real power pro PSU
7- 120 mm fans (they were really cheap)
ASUS M2N-32 SLI Deluxe Wi-Fi MB
AMD X2 6400+ 3.2 GHz
640 MB EVGA GeForce 8800 GTS
Sound Blaster X-Fi Fatality Card
750 GB Samsung HDD
2x Samsung DVD/RW
8GB Corsair XMS 2 PC800 mem
Windows Vista Ultimate 64-bit
and of course, one copy of Crysis....
IIRC, thats really a 450W PSU. Its not a bad system, but IMO, you could have done much better with the CPU, Mobo, RAM, and vidcard. Oh wellz. Next time, ask BEFORE you buy. ;)
do not get the power supply with the cm690. you want a good brand power supply so but them separately. i would recommend either a 450vx or 550vx for your system.
what resolution do you play at? if its not higher than 19xx x 12xx then sli is not worth it.
why not go with intel?
go with th 8800gt, 8800gts g92, or 9600gt instead
8gb of ram? really?? 4gb is enough really..
I agree with the people above :) It's not a bad build, but I would've perhaps docked down the RAM to 4 gigs, and invested a bit more in the CPU/mobo to get the best bang for your buck.
I think he already built the system. ;)
ah ha missed that part went straight to the parts hehe..
yeah its not bad of a system but couldve been much better with the money used.
id go with:
4gb instead of 8gb
8800gts 512 intead of older 8800gts 640
intel instead of amd
