What do you think about this system build.
CDdude55
Please list the parts along with the links. Also, what size monitor do you have? Not OC'ing? Why not?!?!? What will this system be used for? Whats your budget?
Not overclocking because i just dont feel that i really need to. This will be used for mainly gaming. Buget is around $900 or close to $1000. I am buying a pretty small monitor maybe 17 in.
Intel core 2 duo(E4400)
2GB Gskill ram DDR2 800
Asus P5B Deluxe
Evga 8800 GTS 320mb
Thermaltake Toughpower 500w psu
in a super lanboy case.
Your sig is too long.
I would swap the PSU for the X-Clio Goodpower 500w.
Well you will be bottlenecked big time with that cpu unless you overclock. Especially on low resolutions. The e4400 will most likely do 3.0 - 3.2GHz pretty easily so I'd definitely overclock it. But if you're dead set on not overclocking, you'd be better of with an e6750 (not that expensive either).
Thats not a toughpower, its a purepower.... theres a BIG difference in quality between the two lines. I agree with RoBo, go for the XClio Goodpower 500W. Its supplied by CWT, the same supplier for some of the Toughpower models, IIRC.
I doubt it. Sure, there will be a little bottleneck, but I doubt it will be huge.
http://anandtech.com/cpuchipsets/intel/showdoc.aspx?i=2903&p=6
FYI, the E4400 could reach a modest OC very easily on stock cooling and voltage. So, OC'ing it to 2.66Ghz would be as easy as changing a single setting.
E4400: 10 * 200 = 2.0Ghz, DDR2-400 << STOCK
E4400: 10 * 266 = 2.6Ghz, DDR2-533 << Simple OC
E4400: 09 * 333 = 3.0Ghz, DDR2-667 << Nice OC (drop the multiplier)
My E4300 reaches 3.0Ghz on stock voltage, and with stock cooling it idles at 33° and reaches 65° during orthos (ambient room temp is 22°). The E4300 and E4400 share the same OC potential. When OC'ing, if you're worried about stability/reliability, keep the CPU voltage at stock, or near stock, and just make sure the chip stays cool.
