What do you set your cpu fan to?
UnlimitedMP
I was worrying about my temps so I took off my case panel. At first the fan wasn't running when I turned it on and for a few mins and I was worried. Then it turned on and off repeatedly for a while. On 10 secs, off 5 secs, etc. I turned on a game and it seems to mostly be running constantly except for stopping every now and then.
So I'm assuming there's some sort of temp control on the fan that kicks in at about ~50C (temps according to TAT and Coretemp0.95).
What program do you use to adjust your fan at certain temps? Speedfan4.32? Do you have it on constantly?
Or is it a problem with my drivers/heatsinkfan?
You can probably set them in the BIOS. Your MB should have a utility program for use under Windows.
You probably want it to be running at least 30-50% at 30C and full at 45C. What you set it to depends on the exact processor, load and case air flow. There are no hard and fast rules - just set it to stay acceptably cool.
mine runs all the time..I'm pretty sure its supposed too ..:)
I found some info in the mb section. This is something to do with the ds3 and not the hsfan itself.
That's a relief.
Bein' kind of "temp anal" I just run my cpu fan 100 % all the time because I fold 24/7 and I have a hearing defect (3 Zalman 9700's and a TT Big Typhoon) and nothin' has burned out yet. The Zalmans seem to be super quiet. I run a E6600, a E6400 and a E6300 under the Zalmans and probably in the future a E6420, which is under a TT Big Typhoon with a custom higher than stock fan cfm at present (not so quiet, I'm in no big hurry, the Big Typhoon is another great HSF IMO) :D I think you can control the HS fan speed in the BIOS or with mobo included software (depending on what kind of mobo you have). I don't know if the newer Speedfan program works on C2D's :confused: (D'oh, I think the important thing for compatibility would be the motherboard, no sh*t)
I keep mine running around 1500 RPM. However, I can crank it all the way up to 2500 RPM if I desire 110 CFM of cooling fury. :)
i use a 92mm panaflo as my cpu fan and i'm running it at 7v. don't know what rpm that is though?
