Just as you can see below, my RAMs is working on 1684 for now and When I have pushed them 2000MHz, PC just hangs on a black screen at the BIOS boot so I understand they require a bit more voltage. But DRAM bus voltage is enough in my opinion. To What should I give more voltage and how much voltage should I give?
Ai Overclock Tuner - Manual
CPU Ratio Setting - 19
Intel (R) SpeedStep (TM) Tech - Disabled
Intel (R) Turbo Mode Tech - Disabled
BCLK Frequency - 211
PCIE Fequency - 100
DRAM Frequency - DDR3 - 1688MHz
DRAM CAS# Latency - 9 DRAM Clock
DRAM RAS# to CAS# Delay - 9 DRAM Clock
DRAM RAS# PRE Time - 9 DRAM Clock
DRAM RAS# ACT Time - 24 DRAM Clock
(2nd formation: 2T)
CPU Voltage 1.300v
CPU PLL Voltage - Auto
QPI/DRAM Core Voltage - 1.3250v
IOH Voltage - 1.10v
IOH PCIE Voltage - Auto
ICH Voltage - Auto
ICH Voltage - Auto
DRAM Bus Voltage - 1.64v
DRAM DATA REF Voltage on CHA - Auto
DRAM CTRL REF Voltage on CHA - Auto
DRAM DATA REF Voltage on CHB - Auto
DRAM CTRL REF Voltage on CHB - Auto
DRAM DATA REF Voltage on CHC - Auto
DRAM CTRL REF Voltage on CHC - Auto
Load-Line Calibration - Enabled
CPU Differential Amplitude - Auto
CPU Clock Skew - Auto
CPU Spread Spectrum - Enabled
IOH Clock Skew - Auto
PCIE Spread Spectrum - Enabled
