I would imagine you have to maintain a closed water loop regularly to prevent a leak or failure. What do you do to make sure you wont get a leak or the pump will fail or the loop will clog or anything? Ive always liked air cooling better because peace of mind, sounds like a dumb reason, but I dont have to worry about a loop springing a leak and probably frying parts. I feel like it is only a matter of time for a loop to leak or fail, but they probably are replaced and upgraded before they can fail or leak. So for you watercoolers, what do you guys do for maintenance, and how often? Has your loop ever had a leak, if so, how could it had been prevented or what went wrong? Why should one move from air cooling to water cooling?
Thanks in advance!
Thanks in advance!
