Some users have recently had their accounts hijacked. It seems that the now defunct EVGA forums might have compromised your password there and seems many are using the same PW here. We would suggest you UPDATE YOUR PASSWORD and TURN ON 2FA for your account here to further secure it. None of the compromised accounts had 2FA turned on.
Corsair XMS Extreme Memory Speed Series, Low Latency (Twin Pack) 184 Pin 1GB(512MBx2) DDR PC-3200PRO - Retail
Specification
Manufacturer: Corsair
Speed: DDR400(PC3200)
Type: 184 Pin DDR SDRAM
Error Checking: Non-ECC
Registered/Unbuffered: Unbuffered
Cas Latency: 2-3-2-6
Support Voltage: 2.6V
Bandwidth: 3.2GB/s
Organization: two 64M x 64 -Bit
Special Features: New high-efficiency aluminum XMS heatsink, 18 activity LED'S show level of memory activity
Warranty: Lifetime more info-> N82E16820145474 $286.00 $286.00
Western Digital 120GB 7200RPM SATA Hard Drive, Model WD1200JD, OEM Drive Only
Specifications:
Capacity: 120GB
Average Seek Time: 8.9 ms
Buffer: 8MB
Rotational Speed: 7200 RPM
Interface: Serial ATA
Features: Not specified
Manufacturer Warranty: 3 years
Remark: OEM Drive Only more info-> N82E16822144151 $102.00 $102.00
Microsoft Windows XP Professional with Service Pack SP1a - Full Version OEM Designed for reliability, security and privacy, high performance, and ease of use, the Windows XP operating system provides a host of benefits for business and home users. A clean and simple desktop, rock-solid reliability, and easy-to-use features that take advantage of the digital age all contribute to the value of Windows XP.
*Must be Purchased with Hardware!!* more info-> N82E16837102143 $139.00 $139.00
Shuttle 20th Anniversary Special Edition XPC for Socket 478 at 533/800MHz FSB CPU, Model SB61G2R
Specifications:
CPU Support: Pentium 4/Celeron
Chipsets: Intel 865G + ICH5-R
Memory: 2x 184pin (DDR400 up to 2GB)
IDE: 2x ATA100, 2x SATA
Expansion Slot: 1x PCI, 1x AGP
Audio: Realtek ALC 650
LAN: Realtek 8100B, Wireless LAN
Front Panel Ports: 2x USB, 1x 1394, Audio ports
Back Panel Ports: 1x COM, 2x PS/2, 1x VGA, 1x SPDIF_In, 1x SPDIF_Out, 1x RJ45, 1x 1394, 4x USB, Audio ports
Power Supply: 220W
Special Feature: Build-in 16X DVD&6-1Card Reader, Black Aluminum Chassis w/Mesh Cover, Gold Plated Integrated CPU Cooling Engine, Mirror Face Plate, Free XPC Carrying bag more info-> N82E16856101417 $372.99 $372.99
Quite complete, I think. Nice. You may want to go with a 2.6C and overclock, but if you wanna go with a 3.0C, go for it. You may also want to look into the Athlon64 3000+ and 3200+. The Shuttle case may not be available with said AMD motherboard though.
