mjz_5 said:How would internet explorer know which internet connection to download from? It would always pick the primary, no?
Its called routing, type "netstat -r" in your command prompt (Win/Linux/BSD all actually have the same command and switch which shoudl work) and it will show you your current routing table.mjz_5 said:How would internet explorer know which internet connection to download from? It would always pick the primary, no?
Also, I don't know if many do this, but it can also be used in network security where you can have your NIDS listening to your network traffic, without actually being a part of it, but be on a seprate sec system only network to send alerts or data to other systems. Allows you to keep the networks completely seprate, and lowers the chance of compromising. Basicly its the same thing as your first suggestion, just with a bit more of a security focus.Wolf31o2 said:To answer the original question, there are many reasons for having multiple NIC in a single machine. It can be used to reside on 2 separate networks at once, which is probably the most common. Also, with any decent switch you should be able to do 802.11q trunking to aggregate the bandwidth of the 2 interfaces into one. Personally, I use a second NIC as a dedicated link between my primary development machine and my file server. This allows me to access files on my server at full speed without affecting any of the other machines on my network.
