daedal said:Sand Paper
I'd get 4 different grits. 180 to rough up your metal to allow the primer to bond. 500 or 600 to smooth out after the 180, then finish up with 800. Water sand the primer with 1000 grit.
Sandling Block
Use it. Period.
Primer and Paint
Automotive primer with scratch fillers work very well in my experience. Wetsand with 1000 grit in between coats. I'd apply a few coats, depending on what you want to achieve. Same for the paint. Automotive all the way.
