What do i need?
Hey,
I am building a new system all of the specs on which are in my sig.
I have never used water cooling before so i am kinda new to this.
I just wanted to see what you all have to say about what i should get as far as a water cooling system?
I do want to do as much overclocking as i can.
Thanks
If your doing both cpu/gpu its best to do dual loops. I'd recommend:
Gpu:
swiftech mcr 320 w/ med yates
mcp 655 pump
7/16 masterleeker tubing
(2) dtek gfx block
cpu:
swiftech mcr 220 w/ med yates
mcp655 pump
7/16 masterleeker
heatkiller 3.0 block
Thank you so much for your reply.
The only other question that i have is where would be the best place to buy all of these supplies?
