what do i need. v.more sata
antok86
ok im running whs on my server box. im now using all my sata ports on my mobo. its in a rocketfish case so i have plenty more room to add more hard drives, currently i have total of 5 x500gb inside. but if i wanted to add more drives what kind of card do i need to add to pci slots to get more sata ports? possible?
thanks
Any PCI or PCI-e SATA controller will work. How many more SATA ports do you need?
AOC-USAS-L8i - 8 port, PCIe controller (the card is "backwards", components are on the wrong side)
AOC-SASLP-MV8 - 8 port, PCIe controller (normal as can be)
AOC-SAT2-MV8 - 8 port, PCI-X controller (runs in normal PCI slot at reduced bandwidth)
All are $120 (the SAT2-MV8 can be had for ~$85 some)
Supermicro Sat2-MV8. It runs in a PCI or PCI-X slot, has 8 ports and works flawlessly.
