If you have analog speakers, you just use the left/right etc outputs on the mobo - it should be detailed in your mobo manual. If you have digital speakers, or you have an amp you want to use with a digital input, you need a co ax digital cable or an optical cable from the digital out on the mobo to your speakers/amp.
hmm i'm not getting any of this, plus the a7n8xe deluxe's manual doesn't talk in great detail about sound storm.
say if i have some crappy generic 2 speaker setup right now, does this use soundstorm? if i get some nice 2.1 or whatever setup with subwoofer, do i have to buy the co ax thing to make ss work?>
OK, soundstorm is the name of the sound chip on your motherboard. It'll work whatever speakers you use, but obviously the better ones you have, the better sound you get.
Your current speakers probably have a built in amp and are connected to the motherboard via an output - im sure your manual details what socket you need to use to get sound in 2.0. If you want to hear 5.1 sound, you need a 5.1 speaker setup. These vary in cost from $50 to $500 and generally you get what you pay for. The exception is BOSE IMHO, they are way overpriced, but thats another thread.
Theres 2 types of 5.1 speakers, analog and digital. Analog speakers take the sound from the soundstorm thats already been processed into 5.1 (like surround sound for games) and thats output via 3 sockets on the mobo - 1 for front left/right, 1 for rear left/right and 1 for center/sub. Those signals are then amplified by the speaker system. Dolby Digital sound (from DVDs) is decoded and sent via the analog outputs too.
For digital, it takes the dolby digital signal, unprocessed, via the digital out on the mobo (either co-ax or optical output) into the speaker preamp, where its processed into 5.1. Now soundstorm is unique in that in can take non dolby digital sounds (ie 5.1 surround for games) and output it via that digital out so a dolby digital amp can process it properly. A card like the creative can only output 5.1 via the digital out if it comes from a DVD or similar.
So, to sum up, buy the best speakers you can afford if you want good sound, and depending on if they are analog or digital speakers you decide what output on the motherboard you hook them upto.
