I have two 486's. One is a PB450 (120mhz DX4). It will be used for freesco, mostly at lan parties. The other 486 will be a home. The pacard bell needs a case of 28x24x10cm (riser card saves space)
I did hack up an Nec once, and make a heavy-duty case for it out of 3mm sheet metal. It was heavy, and looked like crap.
What i am thinking of now, is getting ahold of plexi-glass, and making a small light frame out of the sheetmetal (cutting out the center, leaving a narrow 1cm wide band going to the bolt holes on the mobo). Since the 486 is wimpy, it doesnt need a fan, and i will make it somewhat air tight. I wanted to take a linux penguin, trace that onto the metal and cut that out, then have it as the top of the case behind the plexiglass. And since lights are cool, i have a handfull of green LED's from old VCR's. I could make a few rows of LED's running down the sides, and have them flash for RX/TX for both NIC's.
But i also had another thought. take that skeleton of a metal frame, and attach some nice wood. Stained oak, or some cool looking wood. I would like this thing to be more like a peice of art, and not like a peice of crap that i would want to hide under a desk.
If you have any ideas, i would like to hear them. By the way, i do have a plasma cutter avalible to me free of charge, and a sand blaster (etching in the linux penguin?) and of course, a dremmel with a few cutoff wheels.
