What do I do with this $1000 harddrive?
Dexmaus
Somehow I got two 15000 RPM Ultra320 SCSI Hard Drive, looks exactly like this:
http://www.newegg.com/Product/Product.aspx?Item=N82E16822332010
My question is what SCSI card to get? I've never had a scsi hd before, so no exp in choosing the right card. I'm kind of running on a budget so I can only spare $80 for it. any suggestions?
How much improve will I see coming from a Seagate 320GB 7200.10?
Should I raid the two HP drives?
The SCSI controller would definitely go beyond your $80 budget; my advice, sell the drives for as much as you can and get VelociRaptors instead.
Well, unless you go low end, you're not going to get a good SCSI card to support that drive. I haven't priced them lately but a good quality Ultra 320 SCSI RAID card couldn't be touched for less than $300.
Even then all of the ones I've seen are either 64-bit PCI (PCI-X) or 4-lane PCI-express. Some PCI-X cards can be used in normal PCI slots but run at half speed and half bandwidth obviously.
QFT. The Veloci-Raptors will blow your mind more than two Ultra320 SCSI drives will and cost a whole lot less.
contact sabregen i know he has a ton of SCSI stuff hes been trying to unload.
2 x Intel X25-M RAID0 will destroy those drives and any other hard drives
how exactly did you get them "somehow" lol
those are server drives people get by stealing them from work.. not worth much.
