what do I do with my XP?
Sorry for the long absence. I have returned, and have replaced my 1.4 T-Bird with an AthlonXP 1800+. I have it running at 1.63. My question is:
Is there anything I should do to the settings in F@H to take better advantage of my new processor? I am running the graphical client version 4.0. It is sailing along well, but I don't know if there are any switches to take advantage of SSE or anything. Any help would be appreciated.
Also, as a side note: Be careful using screwdrivers to remove HSFs from your system. I slipped, one dead mobo. Oh well. Also, do not overclock a Biostar IDEQ with a Radeon 9800 in it. It has been known to blow the PSU. Hopefully, running the cables from a Vantec Stealth 430watt through the back of the case as a ghetto replacement should fix things.
-forceSSE -advmethods
As usual. Welcome back to the Fold.
GET TA WORK, YA SCABBERS!
Welcome back Postalgeist! Slap the two switches mwarps recommended on there and you'll be good to go.
Also try and download the beta FahCore_78.exe core.
Its more stable and sofar I have not locked up with it.
Luck........:D
Thanks, guys. I am turning in WUs a little slow right now, mainly due to benchmarking the new setup. Hopefully next week I will be running full speed.
