dioxholster
- Aug 11, 2010
im trying to overclock i7 920 but have no idea what the threshold is. at 2.6 i get like 70+ frames in BC2 on a hot cpu. I want it the same for BF3. will there be benchmarks done during beta?
http://www.maximumpc.com/article/news/battlefield_3_system_requirements_revealed
Recommended system requirements. Although it doesn't specify speed, I'm assuming you are safe at 2.6ghz. You can overclock, but get a new CPU cooler!
No idea on benchmark.
i will read some guides and see, but stupid question, how do i know its stable? what benchmarking software is most popular and what happens if computer locks up?
Assuming you had enough GPU, GPU RAM and memory; would a Q6600 (Core2 Quad) running @ stock 2.4Ghz be enough to run BF3?
I know I'm probably expecting too much from a four year old CPU.
i just realized something, overclocking is hard! is it just a matter of changing voltages and stuff? how does one figure it out? the ppl for example.
They announced that a long time ago. No DX9 and No Windows XP support. You must have a DX10 card and Vista/Win7 as a minimum. DX11 card is the recommended.reading the sys requirements, no dx9 card support?![]()
Honestly, no DX9 and winxp support? Ok, No DX9, I can sorta understand, although why, I definitely play it at the lowest DX for maximum fps. Fair enough.
No WinXP support? That is fairly stupid of them. I guess I wont be buying the game. Theres $60 they just lost.
Learning to overclock can be quite confusing at first and is not recommended for impatient people. The best way to learn is to use google. When i first started i would google "Overclocking Gigabyte P965-UD3" Or whatever model your motherboard is. You will find hundreds of reviews, and other forum posts from people with your exact motherboard and most of them have the specs they used to achieve their overclock. Once you read through a dozen or so of those you will find the settings commonly used to achieve certain clock speeds.
Just remember to take it slow and not try to go to 4.5ghz on your first boot, and ensure that you are monitoring your temps after each setting you change.
I have a P6T and two 920 CPUs. They are very close in performance, so I wouldn't be surprised if your cpu is very similar to my two.
Your challenge is your DDR3. In order to get a 4.0Ghz overclock @ 190 BLCK with turbo enabled, you would need to get your DDR3 up to 1143Mhz. How much volts do you need to get there? Find out by doing an experiment at 143 BLCK. Set in 1.35V for both CPU Voltage and for QPI/Dram volts. This is important because you don't want to ever let your Dram volts get more than .5V above QPI volts or you can burn out your CPU's memory controller. Asus says 1.65V max for ddr3 volts, but I've heard you can go up to 1.87V before your likely to kill the cpu mem controller, provided your QPI volts are within .5V of your DDR3 volts. In BIOS, highlight DRAM Freq, hit "Enter" and select "1143Mhz" from the choices. See if your DDR3 will operate at 1143Mhz at 1.64volts (you can't select 1.65). If so, you're ready to move on. If you need 1.7v, don't ever set your QPI to less than 1.2v, etc.
Now, let's get you up to 4Ghz or somewhere close...
In Ai Tweaker of BIOS set:
1) Ai Overclock Tuner to Manual
2) BLCK freq 185 (try 180 if it doesn't work)
3) Dram Freq: hit enter and select 1113Mhz (none of the other choices will work for your ddr3) You will need to make a change here if you tested at 143 BLCK
4) CPU volts: 1.35v
5) CPU PLL: 1.96
6) QPI/Dram Core Voltage 1.35v
7) Dram Bus voltage: set in the voltage you've already discovered works with 1143Mhz speed
8) CPU Differential Amplitude: Set 800mV
9) You may leave all other settings as they came in the BIOS
Now save your BIOS and boot up at 185 BLCK. If Vista loads okay, start Realtemp or coretemp and monitor temps. These chips run really hot. See if Prime95 will succeed at 185 BLCK. You are not likely to see a red failure for any of the 8 threads. Instead you'll see a Blue Screen of Death (BSOD). If this happens, go down to 180 BLCK in BIOS and try again. Do not try to make your overclock changes with TurboV software. It is unreliable for moderate changes. Go to the BIOS.
* If 185 Primes okay for 10 minutes, restart your computer and set 186 BLCK and repeat the procedure
* Increase BLCK by 1 each time until you reach 190. You are now at 3.99Ghz
* Should you get a BSOD as you increase BLCK, increase voltage slightly in unison on CPU volts and QPI volts. One of my CPUs needs 1.368volts on each to reach 190 BLCK. The other is happy at 192 BLCK with 1.35v on both.
* When you reach your max stable overclock, run a longer Prime95 session to insure stability. Watch your temperatures! I suggest running these tests on a test stand for better cooling. Consider multiple fans to keep the CPU Cooler cool during Prime95 sessions. With two fast-turning fans on my TRUE120, I max out at 72 degrees on Prime95. I can turn the fans to a quieter setting and fly MSFS X simulator with only about 50 degrees temps later on. Like I said, do what's necessary to keep those cores cool during your Prime95 runs.
* Good luck. Let us know how you do.
In many games you can change the DX mode used. Why wouldnt that be possible. Make it so the game detects the OS. If detected OS is XP, then DX11 or whatever would be greyed out and it runs in DX9 mode. Seems logical to me.
Also, there is nothing wrong with winxp. There are, which obviously you are not aware of, reasons to use winxp over win7 just fyi..... I have both win7 and winxp gaming boxes, I know what I am talking about in this regard.
"also there is no reason a dx11 game cant run just as fast or faster than a dx9 game. i dont think we have gotten a truely dx11 only game from the ground up yet to really see how one will run"
That statement also makes no sense to me. Higher DX = less fps. Period. Always. Obviously newer and more expensive video cards can handle the quality differences much more efficiently than older ones, but that is always true and always the reason for using an older DX mode for people who want maximum fps, not pretty bushes and lighting. No, there is no reason a dx11 game itself cant run as fast as older dx, but the hardware being used could be a reason.
Do i have to overclock the ram as well? from what i read DRAM timings are part of the overclock, which is something i find unecessary because i dont see how it adds to cpu speed? And im using standard ram not meant for overclocking. I will post what im planning to do before messing with anything first.
there are far better optionsgo pick up a Hxx series Corsair water cooling kit.
noctua weighs a ton, takes up a ton of space, is finicky to install (i dont like installing air coolers, but thats just me... its all the cuts i have from them XD), and requires good airflow to work properly. an h60/70/80 makes sense for cases with low airflow, small space, etc.
Gotta remember everything else in addition to temperatures![]()
