got an fx-62 with an m2n32 mobo and I can hit 3.15ghz at 14x225mhz and 3.12ghz at 12x250mhgz. am I safe to assume that I should go with the 3.12ghz (12x250mhz) because the memory would be going at 520mhz rather than 450mhz?
you can assume that the higher the memory, the better the performance-although you probably wouldnt notice the diff anyway. The majority here would tell you, the higher the cpu speed, the better and I agree.
