What cpu, mobo, ram should i get?
darkflames
Ive been an amd user for sometime now, and it seems i need to upgrade my amd 64 3200. I have recently been seeing that the intel C2D is the way i should go instead of buying a amd 4800 s939 and i would also have to buy a new motherboard. Currently i have 2gb pc2700 ram and i took out 1gb seeing what 1gb feels like again and it seems fine to me with the games that i play css mainly. I was eather going to go for the e6300 and overclock it past the e6400 or should i just get the e6400 and over clock it also? Also what would a be a good decent motherboard that i could use to overclock needs to be micro atx and have a pci-e slot. Also 1gb of ddr2 memory preferably 2 (512) so i can do dual channel. Really the most i want to spend is about 350 but dont want to go any higher than 370.
thanks
