What cpu for low temps? Dancases build
snipes23
Limited to coolers for dancases a4, currently running 5930k atx build. Going back to itx build. Not sure if I should go with 7700k, ryzen, stick with 5930k, or wait for asrock x299. Pc is strictly for game use. What would you do. Plan to do a mild overclock. Most likely going with noctua cooler until dan comes out with his hs. Any help appreciated
If it's stricktly for gaming and you want lower temps - go for 7700K. If you are playing at 60 FPS, and you are fine with current temps - I am pretty sure you can stay with your 5930k
Than you should go for 7700k and a Titan XP (or even two of them :D)
