I don't know what I was doing on June 30th, but I eventually did something good. This is the Crysis Benchmark. I was overclocking one of the 4850's and I eventually stuck with 660-1050, and these are the results that I got. I marked these both as a single 660-1050 oc. I'm 90% sure the second result was not with crossfire. These were with the hotfix drivers.
This was just an hour later. I really wish I could remember what I was doing but I almost think that I was just playing Crysis and then decided to run the benchmark again and see how it was doing.
Heres the card with stock settings.
The only reason why I am posting this is because I can't replicate the fps that I made on June 30th.
Besides for my main question, I was also wondering if anyone could test the fps that they get in this benchmark with the same oc. Thanks for reading.
Update: I'm beginning to lead to the idea that maybe I screwed up and didn't know that I had crossfire enabled. The reason why is because my crossfire results almost mimic the results of the test on June 30th. Only slightly better. Back then, I thought that crossfire slightly hurt the performance in Crysis. I know I sound confused but I ran several tests in which the framerate was a couple 10tenths of a fps less. However, I am receiving a nice bonus from crossfire atm. I recently tried the 8.7 drivers, and I noticed the nice crossfire bonus in that. But when I tested a single card, I was only getting 38 fps which was less than the time I thought I got 41. So I rolled back the drivers and decided to run the driver cleaner along with only installing the hotfix instead of installing the 8.6 and then updating to the hotfix.
The one number that leads me to believe that it must of been crossfire is the Recorded/Played Tris ratio: -1.03. What's the chance that those numbers could be the same?
Code:
6/30/2008 7:54:17 PM - XP
Beginning Run #1 on Map-island, Demo-benchmark_gpu
DX9 1280x1024, AA=4x, Vsync=Disabled, 32 bit test, FullScreen
Demo Loops=3, Time Of Day= 9
Global Game Quality: High
TimeDemo Play Started , (Total Frames: 2000, Recorded Time: 111.86s)
!TimeDemo Run 0 Finished.
Play Time: 56.37s, Average FPS: 35.48
Min FPS: 23.01 at frame 138, Max FPS: 46.11 at frame 991
Average Tri/Sec: 36015772, Tri/Frame: 1015026
Recorded/Played Tris ratio: 0.90
!TimeDemo Run 1 Finished.
Play Time: 51.52s, Average FPS: 38.82
Min FPS: 23.01 at frame 138, Max FPS: 46.66 at frame 1014
Average Tri/Sec: 39846132, Tri/Frame: 1026366
Recorded/Played Tris ratio: 0.89
!TimeDemo Run 2 Finished.
Play Time: 51.48s, Average FPS: 38.85
Min FPS: 23.01 at frame 138, Max FPS: 46.89 at frame 1012
Average Tri/Sec: 39874520, Tri/Frame: 1026271
TimeDemo Play Ended, (3 Runs Performed)
Completed All Tests
<><><><><><><><><><><><><>>--SUMMARY--<<><><><><><><><><><><><><>
Run #1- DX9 1280x1024 AA=4x, 32 bit test, Quality: High ~~ Overall Average FPS: 38.835
Code:
6/30/2008 8:59:58 PM - XP
Play Time: 53.82s, Average FPS: 37.16
Min FPS: 21.67 at frame 146, Max FPS: 49.25 at frame 993
Average Tri/Sec: -32983786, Tri/Frame: -887630
Play Time: 48.74s, Average FPS: 41.03
Min FPS: 21.67 at frame 146, Max FPS: 49.77 at frame 984
Average Tri/Sec: -36375704, Tri/Frame: -886521
Play Time: 48.62s, Average FPS: 41.13
Average Tri/Sec: -36460596, Tri/Frame: -886439
Completed All Tests
Run #1- DX9 1280x1024 AA=4x, 32 bit test, Quality: High ~~ Overall Average FPS: 41.08
Code:
6/30/2008 2:37:21 PM - XP
Play Time: 62.44s, Average FPS: 32.03
Min FPS: 24.55 at frame 162, Max FPS: 41.90 at frame 1002
Average Tri/Sec: 32530860, Tri/Frame: 1015598
Play Time: 55.11s, Average FPS: 36.29
Min FPS: 24.55 at frame 162, Max FPS: 43.61 at frame 1007
Average Tri/Sec: 37259296, Tri/Frame: 1026626
Play Time: 55.14s, Average FPS: 36.27
Average Tri/Sec: 37261708, Tri/Frame: 1027313
Completed All Tests
Run #1- DX9 1280x1024 AA=4x, 32 bit test, Quality: High ~~ Overall Average FPS: 36.28
Code:
7/10/2008 3:20:31 PM - XP
Play Time: 52.91s, Average FPS: 37.80
Min FPS: 22.72 at frame 149, Max FPS: 49.86 at frame 1011
Average Tri/Sec: -33574292, Tri/Frame: -888227
Play Time: 48.11s, Average FPS: 41.57
Min FPS: 22.72 at frame 149, Max FPS: 51.30 at frame 986
Average Tri/Sec: -36850000, Tri/Frame: -886462
Play Time: 47.75s, Average FPS: 41.88
Average Tri/Sec: -37097804, Tri/Frame: -885726
Completed All Tests
Run #1- DX9 1280x1024 AA=4x, 32 bit test, Quality: High ~~ Overall Average FPS: 41.725
