what could be the problem
bjamm
I recently built a comp for my friend last week. AMD s754 3100+ semp , with ecs nforce3 motherboard.
anyways now it does not bootup , everything seems to work ok but what is happening is as soon as I plug in the power supply (to the outlet) the computer automatically turns on. what would cause that?
also the power, reset and such dont seem to work? I know they're hooked up right as per the manual, even if the color coding is all wrong on them.
anwyays just wondering what would cause the power to turn on the cpu/fans and such without pressing the power button. I have to flip the switch on the power supply to turn it off. but no video shows up and no beeps.
Could be the power switch button is shorted or is wired wrong. Check the wires going to the power switch. If you can disconnect the wires from the back of the button and see if it still starts on it own.
if i leave all the wires for hdd, power swtch, reset.. leave them all unhooked the mobo still boots up on its on. im lost as to why it is doing this
Hmmm, the key point you mention is that effectively you get no POST (no beeps). This is not good. Have you tried a different video card?
Have you checked the BIOS? I would suggest a reset, then make sure you've got nothing enabled like wake on LAN etc. After that, maybe RMA :(
your board is shorted on something. did you use any extra stand-offs when you installed motherboard to the tray? did you use ANY standoffs when you attached motherboard to tray? also, make sure the start button oe reset button is not stuck/jammed.
take system apart, put motherboard on a wooden table (not anti-stat bag) or on the motherboard box. only connect cpu, hs/f, 1 stick ram, vid card, power supply. use a screwdriver to short the start button pins to start it up. if it boots up, you have a short somewhere in the case. if it doesnt, does it give any beep codes when it starts? if not, motherboard is bricked.
ill try that, but i took it out of the case as well and it still boots up with nothing even installed
no memory, no video card, only cpu/mobo/heatsink. i pull it out of the case, hookup only the power supply and it immediatly powers on. I dont know if its the mobo or not since it was just working on friday and has been working fine.
i didnt use extra stand offs, and yes i did use them. i cant figure it out, maybe ill try to record a video to on my digicam to see if maybe that can help as i've fixed alot of comps but never had this issue where it automatically powers on like this
did you say you reset the cmos?
there is an option in the bios for what it should do in the event of power loss. like stay off, last state, always on.
