what corsair memory has LED's?
Foz2001
im looking to buy some corsair, which ones have the LED's (mostly for eye candy) out of these.?
DDR-RAM Corsair PC3200 (400) 512MB TwinX CAS2
DDR-RAM Corsair PC3200 (400) 512MB CAS2 PRO
and what is twinX? two sticks? is it better?
if i were to get the single 512mb stick and get another down the road would that essentially be twinX?
also im looking and some are twinX Value and others are pro
whats the differences?
Thanks
Are you buying off NewEgg? If you are, here's a list of the one's with the LED's your looking for.
http://www.newegg.com/app/Viewprodu...147&manufactory=1666&description=&srchFor=led
AFAIK, twinX means they come in matching pairs and guareenteed to run in dual channel. It doesn't mean its actually better, its just an assurance that it will run in dual channel. If you got a single stick now and down the road, you get another, it will be as what Corsair calls it "twinX." As long as it's the same speed or if you bought the same stick again. Again, twinX means they come in matching pairs and guareenteed to run in dual channel.
And the last question, I don't know, sorry heh. Wait for an expert to answer that. ;)
