What cooler to choose?
Arcygenical said:
I was worried, but found this:
http://www.bms.lt/?preke=18061
Probably the best on the list. Especially out of the ones I viewed. Also, probably the most expensive.
I hope this helps a bit!
Which cooler do you recommend for ~150lt?
What Zalman is a bit too expensive for me...
Maybe the best choice is to get get water cooler Titan Bianca for ~70$?
Any opinions about Titan Bianca? Maybe somebody uses it?
The Titan Bianca is a very entry-level water cooling kit. It comes with the "water cooling" name, but the CNPS9500 will outperform it, I know that for sure.
Matas said:
Can it be so?
Definitely.
Small-diameter tubing, a low-flow pump, an inefficient radiator, an inefficient block setup, and all you've got is an expensive kit.
Thanks for the help. I'm going to buy Zalman CNPS9500 LED. Is it a good choice?
Arcygenical said:
Yes, it's definitely up there!
I want to push my X2 3800+ as high as it can go. Sadly I don't have enough $ for the good water cooler...
I see that your X2 3800+ is overclocked very well. What water cooler you are using?
