Some users have recently had their accounts hijacked. It seems that the now defunct EVGA forums might have compromised your password there and seems many are using the same PW here. We would suggest you UPDATE YOUR PASSWORD and TURN ON 2FA for your account here to further secure it. None of the compromised accounts had 2FA turned on.
Does it matter which processor you have in determining what saves the most power? B/c I got a laptop with dual core but will getting a laptop that is Core 2 Duo actually help me get better batter life off a single charge?
We need more information, if the current dual core you have is actually a pentium dual core, then yes the Core 2 Duo would be better. However, in all reality, the type of processor won't matter a huge amount. It's more what you do with it.
