I was testing my motherboards yesterday and used an Intel G4400 I use for simple tests and as I was restarting the system it all of the sudden wouldn't turn back on and kept trying to post. It would constantly loop from trying to post and restarting, I could just see the fans spinning up and stopping just to spin again. At first I figured this means my motherboard got shorted somehow. So I tried another board I knew works but same problem. At this point I figure it is the CPU because there is nothing else that I think could be bad. Went to go buy a new CPU and came back with the same issues. This had me dumbfounded as I couldn't figure out what was wrong so I tried a third motherboard I knew worked (Keep in mind all of the 3 motherboard used in this situation was getting POST that same day within the same hours), same issues with not being able to post and it just loops with restarting the fan. I was seeing the red CPU LED on the motherboard so I assumed it was the CPU.
This third board also smoked a little when I had my SSD with the OS connected to the SATA port on the motherboard which eventually made that SSD not bootable anymore. The SATA wire got really hot and I'm confused on why. I shut everything off immediately as I panicked not understanding what is going on. I then tried another PSU since that's the only thing I haven't tried. Same outcome. Tried a third PSU and I got the same outcome also. Tested all PSUs and they all came back good with the PSU tester showing correct voltages and everything. I've been using the first PSU all afternoon to test out the motherboards, everything ran very smoothly then all of the sudden as I was restarting the last motherboard testing it wouldn't turn back on.
I even tried a different RAM stick in case and still won't POST. I'm all out of ideas and am very tired trying to find out what is wrong. Can anyone with experience help me please. I've tried everything i possibly can think of and would RMA the motherboard but for some reason I highly doubt 3 working motherboards were all 3 taken out somehow. Could the first CPU be bad and taken out all the motherboards? Could the PSU take out 3 motherboards like that? I'm deeply terrified of trying another motherboard as I'm afraid to get the same results.
Sorry if this is confusing but pretty much I've exhausted all the options I could think of and still can't figure out what exactly is happening. All of these PC parts worked flawlessly minutes before this happened.
