What case would you recommend for this system
dev1nsan
Heres a link to the components I will be buying to build my first gaming PC.
http://computershopper.com/feature/build_your_own_budget_gaming_pc_1
I'm far from a computer guru but would this Lian Li case work for those componenets, heres the link to it.
http://www.lian-li.com/product/product06.php?pr_index=78&cl_index=1&sc_index=1&ss_index=34&type=b
It looks like a Media Center type case so not sure, if not how bout this case, is a mid tower going to be O.K.
http://www.lian-li.com/product/product06.php?pr_index=25&cl_index=1&sc_index=1&ss_index=5&type=b
Oh and where do you guys purchase Lian Li's at, direct on their website.
Feel free to make any suggestions to the main components, I've already got the keyboard, mouse, headphones and monitor.
yer man u should be ok with the media one but the tower has better cooling
I have the 607 ... and it is a nice case, but with some issues. The overall structure of the case, and build quality is AWESOME .. and it is really silent (i muffles my X1900XT!!!!). With the silence comes a price, the airflow in there is AWFUL for high end components ... AWE-FULLLLLLL!
But, if you are looking for a solid, midtower that will house mid-range components silently ... you will be fine going with the 607
mark660, so i'll be fine with the components from that site if I use that media center one?
yer i dont see y theres a problem the case has an ok cooling sytem and that so yer so go for it
