what case to work with?
So Com ST
Ok, just got into the modding, and I have this premod. Now I'm kinda tired of the limits of this case so I am going to get a new one and mod it. Now the thing is i don't know wich one.
I have a cc-0824 and i need something taller and posibally longer.
120mm only!
I want the bottom front flat enough to make a 120 mm hole without moving the power/restart.
room to make 120mm hole in top closer to front as possible.
Need about 5 cm space from my atx motherboard and power supply to fit a zalman cnps7700-cu(stock fan is noisy)
Preferably no window. (want to add myself)
metal, no platic/bezel top/flont.
and lastly avaiable in canada
If anyone can help, please do so.
PS: Seer, if you reading this, i got a micros computer plus by me.
I dont know which one to suggest, but you could go to Dealsonic or ebay and just browse thier cases to get an idea of what you want. If I have time I might look around for ya.
It is all about the stacker, or yo ucould wait a bit until they release the rumoured smaller one (missing the bottom power supply location and hence 3 drive bays shorter). Or anything by Llian-Li or silverstone, a coolernmaster centurion, the list is endless.
Kingwin?
I am encouraged by how simple and good their cases are.
I am not talkin those mutant ones, i am talkin those 85-100 black ones w/ or w/o the side panel window.
well the cm stacker is almost perfect but the most obviose catch is moolah, dough, cold hard cash. $215 here in canada.
Thats why i suggested waiting for the slightly smaller one thats rumoured to be coming out. If youre gonna properly mod the hell out of it though a cheap Full tower case should do what you want for cheap, and if youre gonna go the whole hog with mods it doesnt realy matter what it looks like to start with.
i think i might go with this one. the 2nd power spot would help and enable be to put in a zalman cnps 7700-cu cpu cooler on my processor
Youll be able to fit it even without the second psu place, i could easily fit one in here with the psu in the top location, although it would overhang if you want it in BTX mode.
What board is it? I was talking about in the stacker, theres clearance for stuff like that at the top, but ive seen other boards in chaepo premods with cnps7700s on there, specifically my housemates A8N SLI
