What Case should I use?
flooberjobby
Hi I am builing a computer using this mobo Asus 2ZS WS, wich is a SSI CEB form factor mobo.
Only cases I have found that interested me was these two following cases:
http://www.newegg.com/Product/Product.aspx?Item=N82E16811147101
http://www.newegg.com/Product/Product.aspx?Item=N82E16811133068
The system will be moved around alot, and it has to be able to help keep the components cool. I plan on using really efficient silent fans to cool the system because water cooling is to much right now. As it is the system is expensive and I need to buy it slowly peice by peice, wich is going to kill me to no end and drive me insane not being able to use it to it's full ability right away.
It will consist of the following parts when it is completely done.
24 gigs of DDR 2 800mhz FB-DIMMS
2x 300Gig 10,000 SATA 3Gig Raptors
2x e5420 Xenons OCed to 3.2ghz
Corsair 1000HX, and if need be I will also buy the 5.25 single drive bay power supply by thermaltake that is 450W.
I will also be getting a 30in monitor eventually as well.
Vista 64bit, not sure if I will have Premium or Ultimate yet.
