45454asasa
- Nov 6, 2010
I have been looking at cases for a few days now but I cant seem to find an answer on what kind of case works best for graphics cards that blow the heat back into the case.
Currently I have a Stacker 830 and its not doing well at all at cooling a 7950 Vapor-X. I haven't got any side panel fans on as the fan holder cant fit with the CPU heatsink in the way.
This is my understanding of what is happening in the case, from a side view.
Blue = Intake
Red = Exhaust
Red Block = GPU
--I forgot to draw the two intake fans on the bottom of the card. Imagine them
The GPU has very high pressure air going thru on all directions, and it basically chokes the front intakes from doing much of anything. For that, I tried putting a fan on the mesh below the card, but it really didnt help.
So,
My initial thought was a sealed positive pressure case, like the 550D w/out side fans... but reviews show it has pretty poor cooling. Of course, with more fans it will be better... but then it's carrying a premium for silence when I dont intend for it to be silent, nor will it be with the fan covers' lids taken off.
So then I looked at the HAF X on the other end of the spectrum, but thats almost as open as a Stacker. And with low pressure large fans, I'd imagine the front fan would be fighting with the GPU's exhaust again. The side fan might help a bit, but its still not going to do any wonders, right?
Are there better options, like a sealed case that pushes air over the GPU, front to back? Or would putting Performance SP120's on the 550d do just that?
Thank you.
Blue = Intake
Red = Exhaust
Red Block = GPU
So,
Thank you.
