What card to get? pleae help
justin8018
9600-$69.00
9600pro- $103.00
9600Xt- $132.00
9800SE- $130.00
*9800- $145.00
*9800Pro- $155.00
*9800pro 256 bit - $197.00 powercolor
6800- $270.00
these are my choices i have a x800 in my main system, but i just pu together a sff, and i'm not sure what card to get. it has xp3000+, 512 pc3200, what is the best for the price I want the 256 bit 9800 pro, or a 9600 but what one? please help.
the 9800 Pro with 256bit memory would be the best-bang-for-buck card...but your choice also depends on how much money you want to spend and what you want to do with it...
well, its simple... 6800 1st choice.... and 9800 Pro 2nd choice....
You get what you pay for.
The 6800 would be the best and probably last the longest.
justin8018 said:
what if i wanted a 9600 are they bad, will i be able to play new games?
well...you could play them...but it'd have trouble keeping up
Since you want to play the newest games I'd say go for a 6800GT...but since that's not on there then add another vote for the 6800.
If you have the extra $70 to spend on a 6800 it's worth it. 9800pro will perform well with new games but the 6800 is really an entire generation ahead and much more powerful.
