what card can....
-=ABUSIVE-69=-
...play CSS, HL2, DOD:S, ect... at MAX detail at 2304x1440 with good frame rates? (pci express 16x, no sli, as cheap as posable)
thas one hell of a resolution, id say a 7900gtx sli or 1900xtx crossifre with a nice comp to go with it... that would be pretty taxing
yeah, just got my fw900 to replace my old 17inch lcd. after plugging it in to my 5700le i realized thast i need a better card for my new build:
pentium d 920 (will overclock to 4.0ghz)
abit aw8
1 gb ddr2 667
15000rpm seagate 36gb drive + 160gb 7200rpm drive
Why are you buying a 15k HDD? Those drives are optimized for multi-user environments, the most "economical" high-RPM drive is the 150GB Raptor. And why only 1GB of DDR2? 2GB is the sweet spot for games these days...
Because SCSI pwnz0rz j00.
:p
I say 7900GT / x1800xt 512 BARE minimum.
i got the 15k because i can :D and its fast :D i will soon upgrade to 2gbs when i get the $$
are you sure. can't he play with a single 7900 gtx? the 7900gtx is pretty powerful as long as you disable most eye candy.
im just going to get a 6800 ultra now because i got a good deal on ebay. i dont need to play games at native res i guess. i will wait for DX10 cards to spend $500+ on a top-of-the-line card
