What can i get to improve performance?
UberPooner
Hi, these are the current specs on my computer:
asus a8nsli board
2g corshair xms pro ram
amd 4000+ (2.6ghz)
7800gtx
i was wondering what i can get to get a big performance gain in my computer wihtout having to buy a new motherboard.
An 8800GTX is about the only thing that will improve your system other than a dual core CPU. Though, if you get a dual core CPU, make sure it can at least run at the same clockspeed as your current CPU, otherwise, you may not notice a performance improvement.
If price is no barrier then, 2x 8800gtx + An FX60, .. Add another 2 gigs of ram and a psu capable of running all of that also.. Well that's my wish list in your shoes without changing your mobo anyway..
Otherwise for around $600 a 8800gtx, or a 8800gts in the $450 area or a x1950xtx in the $400 area.. For games your cpu is fast enough for the most part, but a X2 at or above your current cpu clock speed can't hurt..
