What Can I do to go higher?
Nightcast
[H]ere for the Blow!
Ok So right now I'm running @ 2500.7 MHz
My FSB Is 250 and If I go any higher the system will not post.
Is there any thing else i can do now to reach like 2.7, 2.7 GHz
Anybody? Im sure its just a quick and easy answer that I can't find out myself.
i'm not that experienced with overclocking, but i would think it would help to loosen your ram timings a bit. does anybody else think that would help or am i just shooting blanks?
Depends on what speed his memory is rated for.
If you could post the rest of your system specs, Mobo, RAM, etc we could probably help you out a bit more.
CPU: AMD Athlon 64 3200+
MB: LANPARTY UT nF4 Ultra-D
RAM: 2x512mb of DDR pc3200
HDD: 160gb Wester Digital 7200rpm, 200gig Seagate 7200rpm
GPU: GeForce 7300 GT
PSU: logisys 550w psu
OS: Xp Pro
Theres my system specs.
I've droped my HTT Multiplier to 3, Heres a update.
I take it you are running at stock voltage? Not all chips are guaranteed to run at high speeds with no voltage bump. You can also try up to 1.4 since most coolers today can easily handle that much voltage.
