Tommorow I'll be starting my first custom case, and some of the construction will be with plexi-glass. If possible, I would rather buy one large peice and cut it into desired sizes than have a hardware store cut it for me, but I was wondering how hard it is to cut plexi-glass.
I have a variety of tools available, and personally figured a sabre-saw would be the easiest to use assuming I can get a blade for it that won't make the plexi-glass splinter or feather.
Any hints or ideas? Any types of blades for sabre-saws that are ideal for this sort of work?
Or is there simply another tool I should be using, and if so, what is it?
Thanks,
Erik
Thanks,
Erik
