I've got an old system that keeps freezing when I'm using it and I can't figure out why.
Occurs:
- Sitting idle for short or long time
- Running under high load, or web browsing with nothing else going on
- Any time, could boot and freeze in a minute, or last 24 hours
Tests:
- Memtest ran fine for 36 hours, tried 2 different sticks, same result
- Prime95 ran fine for 12 hours
- Swapped PSU, same results (current PSU fine in other rig)
- Mobo is Abit VH6, I RMA'd it for leaking caps... issue occured with old mobo, and still does
- Swapped Videocard
- Reformatted system
- Locks up randomly in WinXP and Linux environments
Haven't swapped:
- HDD -> Quantum 30GB (5 years old and LOUD)
- CPU -> P3 733Mhz
My thoughts:
Well I really dont know what the cause could be. By process of elimination though, it can only be the old CPU going bad, the HDD going bad, or the new mobo from RMA isn't good. None of these possibilities make sense in my mind, so let me know what you think the cause is. I don't think I've left a stone unturned here.
Occurs:
Tests:
- Swapped Videocard
Haven't swapped:
- CPU -> P3 733Mhz
My thoughts:
