i'd like to know your experiences with these 3 RAID options (i'm thinking of running RAID 0)
did you notice a significant increase in performance using RAID 0? ever crash?
things to keep in mind about me: i don't really have anything important, i already have wut is important to me backed up on DVDs
added: important
wut stripe size should i use? i'll be burning 3 movies at a time, maybe play CS:S if my computer can handle it
i was reading and i read that i could find the best stripe setting
added: important
would this formula be right?If you go into XP disk defragmenter and click on Analyze for your array, it should return a value of the average file size.
Take this number, and divide it by 2 x # of harddrives in the array, then round DOWN to the nearest available stripe size you can choose.
Let's assume that the average file size on your harddrive is 512Kb.
Divide that by a factor of the above calculated number. In my case, I have 4 harddrives in my array, so I would choose 8.
So, 512Kb divided by 8 = 64K (the optimal stripe size for my average files).
Let's say you had 2 harddrives in the array, then using the above formula, you would choose 128K stripe size.
