What are the best bang buck budget wireless headphones for the money?
Discussion in 'Computers & Gadgets' started by passion4tech, Apr 25, 2017.
  1. passion4tech
    passion4tech Limp Gawd
    153
    May 11, 2016
    I can't comprehend why apple decided to remove traditional headphone port iphone 7 but anyway what are best budget bluetooth headphones for iphone 7?
  2. Bandalo
    Bandalo [H]ardness Supreme
    4,752
    Dec 15, 2010
    Define "budget".
  3. SticKx911
    SticKx911 [H]ard|Gawd
    1,901
    Mar 14, 2004
    Audiophile? Don't listen to me. Otherwise my family owns a few of these and I have a few friends at work that use them. Pairing is great. Connects to two devices at once, and the ear piece retention is good. Audio quality is meh, but my use is more reliant on dependability than awesome sound quality. I've owned at least 5 different budget sets (ie Chinese knockoffs) and these are the only ones I'd recommend.
    Mpow Jaws V4.1 Bluetooth Headphones Wireless Neckband Headset Stereo Noise Cancelling Earbuds w/ Mic https://www.amazon.com/dp/B015IEW1AY/ref=cm_sw_r_cp_apa_v82.ybNE3FJ2C
  4. Libertad
    Libertad n00bie
    44
    Dec 30, 2010
    I own 2 pairs of JayBird Bluetooth earbuds, they work great, battery life is decent, so is sound quality.
  5. passion4tech
    153
    May 11, 2016
    hey guys the reason I made this thread is because a buddy of mine asked me what are best bang for buck wireless headphones for her iphone 7? Are there any audio technica wireless headphones that are overall great bang for buck? I did research & I notice a lot of wireless headphones on amazon receive mixed reviews.
  6. passion4tech
    153
    May 11, 2016
    My buddy ended up buying AKG Bluetooth Headphone Black (Y50BTBLK)
  7. FeelGood
    FeelGood n00bie
    5
    Jul 28, 2017
    I don't like these headphones
  8. passion4tech
    153
    May 11, 2016
    OK that's like your opinion man.
  9. FeelGood
    FeelGood n00bie
    5
    Jul 28, 2017
    Yes you're right
  10. Seankay
    Seankay Limp Gawd
    262
    Jul 20, 2016
    Bose SoundSport Wireless is pretty good if it is considered a budget one!
  11. DGMurdockIII
    DGMurdockIII Limp Gawd
    267
    Jan 16, 2015
  12. joshy111
    joshy111 n00bie
    19
    Jul 20, 2017
    I personally use the Jaybird X3's they really have great audio and are really comfortable for me.
    Though they aren't the cheapest option out there though if you do look around I am sure you can get them for under $100 and to me they are good value for that price.
    Here's a decent resource about wireless earphones if that's something you are looking for - http://www.flipflopsandapplesauce.com/best-bluetooth-earbuds/
  13. Larry Gilmore
    Larry Gilmore n00bie
    33
    May 4, 2017
    Thanks, friend I'm also searching for the best Wireless Headphones and here every gives great advice about it. Thanks, friends I will check all that you guys mention and check which one is in my budget I will buy that one. (y)
  14. Darkh Prophet
    Darkh Prophet [H]ard|Gawd
    1,477
    Aug 10, 2006
    Anyone have experience with Skullcandy Crushers? Seems to have a lot of good reviews/ratings: https://www.amazon.com/dp/B00E1CSEMO
    I owned a pair of earphones a few years ago, but they broke (can't recall if it was b/c of my negligence or if they legit died). Wondering if the quality has gotten better since...?
  15. brentom
    brentom n00bie
    7
    Nov 19, 2017
    Bose Soundtrue II is a decent headphone and not pricey.
  16. tporter
    tporter [H]Lite
    65
    Mar 7, 2013
