What are some ways around Toshiba's "Wrong Machine" error?
LABachlr
I have a client who has a Toshiba tablet PC (not sure of the model number) who wants to upgrade their hard drive to a larger hard drive.
When I upgraded my hard drive on my Toshiba, it gave me the Wrong Machine error message. I tried using the DMI update tool, but it gave me a choice between 2 model number series, both of which were not the series of my laptop. I tried updating each one, but neither update worked. So eventually I had to use a retail XP CD to install the OS.
So, the first question is do Toshiba laptops always give the "Wrong Machine" error message when you replace the hard drive with a larger one?
And the second question is, if so, how do you get around that if the DMI update does not work and you do not want to go out and spend money on a new OS CD?
Ive installed newer larger hard drives on toshiba's and have not gotten the "wrong machine" error. If i did i would use the DMI utillity. Other than that I dont think there is away around the wrong machine error.
I tried updating two freebie Toshibas from my niece with larger HDD's ....I received a prompt that the hardware isn't compatable, but can't remember the exact phraseology....in any case, it would depend on the BIOS and OS whether it will accept a newer/larger HDD.
