What are some sleek looking keyboards?
the razer lycosa is pretty decent. i just got one a little over a month ago and have been pretty happy with it.
I'm definitely going to pick up that Logitech Illuminated Keyboard once my Saitek II dies.
i m picking up the Dinovo Edge myself
my trusty MX Duo finally certified today...
after 4-5yrs of hard work... time to recycle them =/
i wanted to keep them but i just dont have the space...
i have a lycosa as well.. great keyboard.. horrible quality.. i use my keyboard heavily.. and do a lot of gaming as well.. after about 4 months the covering on the keys started wearing away.. so as of right now after 6 months all i can see is the blue LED coming through these keys " w s d c b n m o (enter key) (tab key) (left ctrl key)..
so i guess if your not a heavy user like i am.. this is a very good keyboard.. biggest buying factor for me was that the wrist guard was removable.. because i friggin hate the wrist guards.. cant figure out how anyone can use those things..
Enermax aurora, I just picked this up super cheap after a store made a mistake on they're website and didin't charge me the difference. This thing will last for years, and it has never ever moved while I type. Good for game too as I played cs 1.6 on a laptop for a while.
most of the new logitech use the strange modified layout where the del-ins-home-pgup etc buttons are vertically aligned instead of a 3wide by 2high orientation they were always in.
If you care about that, the ultrax above seems to give it to you and the closest wireless one seems to be the edge for notebooks. But, for some reason they made the delete button double-high and the insert button tiny and where print screen should be :confused:
I also have the mx-duo setup, love it they keyboard is a bit bulky but the layout is 'original'. Mine is slowly dying as well though...
Thanks for the suggestions I'll try check out a Razer lycosa, looks quite cool.
