What and where 3.2C???
KingPing
I was curious what the terms 30cap and 12 cap refer to? I am in the market for a 3.2C and I like to overclock. So from what I've been reading I should look for a 3.2C,SL6WE,30cap??
If that is correct can anyone point me a direction where i may find one??
thanx in advance KingPing<----nub
It refers to the "caps" on the bottom of the cpu. Not 100% sure what they are for. The rare 30cap variety seems to be the better OC'er. Of course you might get one and it won't OC worth a crap at all. Such is the risk with overclocking. You never really know what you'll get.
You need a bit of luck, most 3.2c's left should be 30 caps as they came out after the 12 cap ones, however beware the newest SL792's (with 30 caps) as they are the SL793 (P3.4c) rejects so probably won't overclock as well.
